Always keep or protect original image
Perseus83
Post by Perseus83 »
While editing a specific image I can only select to "save" and overwrite the original image or to "save as" new image.
While working with other image editing tools, I'm used to have a feature that always protects the original image.
Is there a way to set something alike?
Thanks a lot!
Andreas
Re: Always keep or protect original image
you don't want that 'Save' is available?
Perseus83 wrote: Tue May 30, 2023 1:21 pm While working with other image editing tools, I'm used to have a feature that always protects the original image.
what software/feature?
- save a copy (similar to 'save as')
- export
- auto backup
- ps adjustment layers/smart objects
- sidecar xmp
