Driver Cleaner Pro (freeware) - Releases thread
All non-XnView related: softwares, formats, imaging, photography...
ckit
Post by ckit »
Driver Cleaner Pro 1.3:
Helps you to remove parts of drivers that are left after uninstalling the old drivers. The program is for ATI, nVidia, Creative, Realtek, SIS, 3Dfx, S3 and more drivers. First you need to uninstall the drivers from the control panel, then reboot. After rebooting, run the program. If you really want a good description of what steps you should take, then you really need to read the readme file included in the zip file and installation as it contains a detailed step by step description. The program also fully supports windows themes and other kind of themes.
Version 1.3 (Date: January 05, 2006)
Added:
- 3Dlabs Wildcat 4 cleaning file
- 3Dlabs Wildcat REALIZM cleaning file
- 3Dlabs Wildcat VP cleaning file
- ATI TV Wonder cleaning file
- VIA Envy Audio cleaning file
- VIA HD Audio cleaning file
- VIA Vinyl Audio cleaning file
- Albanian language file
Updated:
- ATI cleaning file
- ATI WDM cleaning file
- ATI Uninstall Utility cleaning file
- nVidia cleaning file
- Realtek AC'97 cleaning file
- Italian language file
Improved:
- Registry searching routine
Fixed:
- Cab Cleaner not working good when cab file was read only
- Cab Cleaner did not clean the cab files in the windows\i386 folder
Homepage:
http://www.drivercleaner.net/
Screenshot:
ckit
Driver Cleaner Pro 1.4
Post by ckit »
Driver Cleaner Pro 1.4:
Version 1.4 (Date: January 21, 2006)
Added:
- Belarus language file
- Czech language file
Updated:
- nVidia WDM cleaning file
Fixed:
- Cab Cleaner did not clean the cab files in the windows\driver cache\amd64 folder
Homepage:
ckit
Post by ckit »
Driver Cleaner Pro 1.5:
Version 1.5 (Date: March 04, 2006)
Added:
- Version check to see what the latest version is online
- View filters version number in settings screen
- Cleaning filter profile saving and loading (View help for details)
- Razer Mouse cleaning file
- SoundMAX Audio cleaning file
Updated:
- 3Dfx cleaning file
- ATI cleaning file
- ATI CCC cleaning file
- ATI MMC cleaning file
- Creative Audio Lite cleaning file
- Creative Audio cleaning file
- nForce Chipset cleaning file
- S3 Savage cleaning file
- Some Language files
Improved:
- Full registry backup routine
- Cab Cleaner Code
- Help file
Fixed:
- Bug in settings screen with folder size text
