Hi all, I made a simple application to integrate DeepDanbooru (image tag estimation system) and XnView. Also its possible to use it to simply assign categories (tags) with XnView via JSON files. So I would like to share it with the community.
You can download current version here:
https://github.com/b4dp0ssum/XnView.Mar ... _0.0.4.zip
or visit my GitHub page:
https://github.com/b4dp0ssum/XnView.Markirator
P.S.: I hope my actions don't violate the XnView rules..
DeepDanbooru and XnView Integration Tool
EricRollei
Re: DeepDanbooru and XnView Integration Tool
Hey that's pretty neat. I may try it. I'm not sure I totally understand the usage instructions though. Let me try and see if I can figure it out.
Probably my manual (and the tool itself) is not exactly user friendly. If you have any questions, I will try to answer them.
