B3: Program doesn't open target of shortcuts (image, folder)
Dreamer
Post by Dreamer »
Taken from other topic.
majalid wrote:Program doesn't open target of shortcuts (image, folder). (1.80.3)
1.82 beta 3:
Image shortcuts:
- from explorer - OK
- from xnview - OK, but it's opened in new xnview window
Folder shortcuts:
- from explorer - error dialog
- from xnview - error dialog
But now - all shortcuts, images/folders, are invisible in xnview, strange.
XnView 1.82 <x>
Re: B3: Program doesn't open target of shortcuts (image, fol
Dreamer wrote:Taken from other topic.
1.82 beta 3:
Image shortcuts:
Folder shortcuts:
Currently xnview doesn't support folder shortcut
Dreamer
Post by Dreamer »
Do you plan to support it? Currently new program (explorer/file manager) must be opened to just enter the folder (shortcut).
What about this:
XnView is able to open it, just it should be opened in the same window, is it possible to fix it?
Dreamer wrote:Do you plan to support it? Currently new program (explorer/file manager) must be opened to just enter the folder (shortcut).
Not for this release.
What about this:
When you click on a thumbnail??
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:XnView is able to open it, just it should be opened in the same window, is it possible to fix it?
Yes and with default settings image/shortcut is even opened in the new tab/same xnview window. With option "Only one view opened" it works good (images). Folder shortcuts works partially too - folder is opened in explorer.
But - with my old ini, images were opened in the new xnview window and folders didn't work completely, strange, but I don't have this ini. :(
And... (I'll start new topic for another problem).
When i click on a file shortcut, i have it in preview, so no problem on my side... ??
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:
xnview wrote: When you click on a thumbnail??
No, with default settings it works good, I just had a problem with my old ini, but I can't confirm/reproduce it, because I can't even see any shortcut files now (another problem/another topic).
Dreamer
Post by Dreamer »
Image shortcuts: fixed in RC2 (or 1).
Folder shortcuts: opened in explorer...
...Maybe I know where is the problem, xnview thinks that folder shortcut is file, if you'd tell him it's a folder it should work, but you must decide when (1.82/1.83?) Pierre. Hope it will helps you.
Dreamer wrote:Image shortcuts: fixed in RC2 (or 1).
Please postponed
