How to get the 'Google format' GPS coordinates from the EXIF properties?
mrwul
Post by mrwul »
At best I can extract GPS location like "52 deg 9' 16.70" N, 15 deg 23' 13.49" E
I would like to get the 'Google format' like: 12.345678, 12.345678
When pasting the 1st coordinates, Google returns that it can't find it.
If it is not possible right now, maybe as a new feature, to add an option showing the GPS coordinates the Google way?
Thanks!
Re: How to get the 'Google format' GPS coordinates from the EXIF properties?
Post by michel038 »
Select the photo, Tools>Metadata>Edit GPS > Copy
Paste into G. maps and delete the last value (alt) ...
You can also open the photo in view mode, right click > properties ... display the GPS tab where the Google map can be shown in a large window, with the option of obtaining a satellite view.
mrwul
Post by mrwul »
Thanks.
Within Tools, I am afraid I don't have no Metadata>Edit, etc.
So far I r-clicked on the photo, properties, then selected EXIFTools
BUT...
I just 'discovered' under Tools > Open GPS location in > Google Maps.
It then shows the 'Google format' !
Great!!
I wasn't aware of it.
Matter solved.
Thanks again.
Post by michel038 »
- Open XnviewMP (Browser mode)
- Do not open the photo in view mode,
and
mrwul
Post by mrwul »
Ah, right, there it is... :)
thanks a lot.
