No sound/audio when playing video files in XnView MP
dufourquet
Post by dufourquet »
Hi
I am trying to resolve the following issue.
I am running the XnView MP 1.4.5 version on macOS Catalina.
In the Browser mode, I see all the video files thumbnails. When I click on any of them, the video playback works fine but the sound is mssing for all kind of video files. The sound button in the View mode shows 100% but no sound is playing.
(Yes, the other apps in my computer do play the sound correctly.)
Any suggestion, please?
Re: No sound/audio when playing video files in XnView MP
audio volume is good? I've tried on MacOS Catalina, and no problem for audio
Orfanomondo
Post by Orfanomondo »
I suddenly lost all audio/sound on MP4 files. The video files are not corrupt. I can play the same files with MS Media Player and VLC with full audio. My audio and volume settings are correct; I can play other videos, such as YouTube and TikTok, without any issues. I cannot find any audio settings. I downloaded and installed MP again, no change. Is there a "reset button" or "return to factory settings"? Quoi faire?
Orfano Mondo
Orfanomondo wrote: Wed Aug 20, 2025 12:34 am I suddenly lost all audio/sound on MP4 files. The video files are not corrupt.
and other video file?
Orfanomondo
Do you mean other formats than mp4? I don't have any other video types at the moment.
Orfano Mondo
Orfanomondo
Crisis averted!
After three days of no sound, I started digging for videos in other formats, and I found, deep in my cloud folders, two MOV files.The sound was there; beautiful organ music from Saint-Sulpice taken with an old phone many moons ago. After that, I tried playing mp4 files again, and lo and behold, the sound was back! Life is back to normal, all by itself.
Orfano Mondo
Orfanomondo
I am sorry to go on about this.
Something is not right. The sound is intermittent. I closed MP and started it again, the MP4 sound was not there. Then I played the MOV files first, and it worked, once. There was sound on mp4s as well. Again, I closed MP and restarted it, and now the sound is gone, in both file types. No sound on MOV files either. Any ideas?
Orfano Mondo
in your xnview.ini what are the values for the 2 'audioVolume'?
Orfanomondo
audioVolume=100
Both times.
Orfano Mondo
why you dont use latest version?
Orfanomondo
What should I do? I am running Xn MP 1.9.3.
Orfano Mondo
Orfanomondo wrote: Wed Aug 27, 2025 8:44 pm What should I do? I am running Xn MP 1.9.3.
Please send us your xnview.ini
Orfanomondo
Sent by email.
Orfano Mondo
jamesmwphd
Post by jamesmwphd »
I’ve run into similar audio headaches with a few different media viewers, not just XnView. Usually, the issue was some weird conflict with codecs or the way the app accessed system audio, even though everything else on the Mac played sound fine. Once or twice, restarting the app or toggling formats would make the sound come back randomly, kind of like what you described. It’s frustrating because you start second-guessing if it's your files, settings, or the app itself. When I wanted a reliable way to just play back and also capture what I needed (with audio, no drama), I found it a lot simpler to use tools built specifically for recordings, since most of them tend to handle all the audio sources smoothly and let you annotate stuff, too. Sometimes I opt for a screen recorder to quickly save or review a video, especially if playback keeps glitching in the viewer. There are some free and paid options, like https://www.movavi.com/screen-recorder/, that make the whole process easier and tend to sidestep codec problems.
