Anyway to disable/delete all the output formats I'm not using.
acoolrocket
Since I just use jpeg/png/webp/psd, I want a way to disable or delete all other output formats since its just too much to go through.
Re: Anyway to disable/delete all the output formats I'm not using.
you can try to edit xnconvert.ini and change formats
acoolrocket
Any lines I should look into in the .ini, admittedly already lost?
sorry but i don't understand
acoolrocket
As in what code/parameters in the .ini I should change.
You can select which save formats are displayed on the Output tab here:
Settings tab > Load format settings... button > Save tab...
Possibly a new option in 1.98?
No change lists for XnConvert yet...
for exampleacoolrocket wrote: Wed Jun 14, 2023 11:43 am As in what code/parameters in the .ini I should change.
formats=jpeg, gif, png-
acoolrocket
There's no save tab for me, its Camera RAW, PS/PDF, OpenEXR, HDRI, PSD, RAW, PCD and FITS..cday wrote: Wed Jun 14, 2023 11:54 am You can select which save formats are displayed on the Output tab here:
No change lists for XnConvert yet...![]()
Settings tab > Load format settings... button > Saving tab...
acoolrocket
This is what mine's looks like:
That is the Settings tab > Load format settings... button > Read tab...
I am using XnConvert 1.98, on Linux which shouldn't be relevant, and I have Saving, Read and Write tabs as shown in my screenshot above.
But I did erroneously refer originally to the Output rather than the Settings tab, my mistake...
If you don't have those tabs which version are you using?
acoolrocket
Wops 1.96, updated to 1.98 and its now there and working!
Welp that was awkward, thanks for that reminder. Maybe add an auto-update feature?
The Settings tab has a Check for program updates option...
Mine is set to the, probably default, value of Weekly but not sure whether I ever get any??
