Navigation for scanned documents: View on top when next image and zoomed
corr
Post by corr »
I wish there was an option where if you view an image in full screen and zoomed, when you switch to the next image, it is displayed again at the top.
This feature would be extremely useful, especially when reading scanned documents or manga that I view normally zoomed to page width. Currently, when you zoom into an image and then switch to the next image, the subsequent image is displayed at the position of the previous image, in this case at the bottom. This means you have to manually scroll back up for each new image, which is a bit inconvenient.
Additionally, it would be helpful to have a function that allows you to scroll through an image from top to bottom. At the bottom of the image, the next image would then be displayed, separated by a dividing line. Similar to a PDF viewer in continuous view mode.
The whole thing could be called document view mode between which and the normal view one could switch.
