View tagged image shorcut
Gwenael Q.
Post by Gwenael Q. »
"View > Tag > Show tagged files" command behaves as a switch. User can activate or deactivate this behavior with the same command.
May I suggest to allow the dedicated shortcut Shift+T to behave the same way ? Currently, it only activates the command.
Thanks for listening
MP 1.4.5
