Post
by user0 »
XnViewMP 1.4.5 64bit
Slideshow - transition effects
- Expand quaters
effect is the same as Wipe quarters, it shall be opposite (expanding from center)
- Slide quarters
bottom-left part of effect is incorrect (it duplicates top-right part)
Post
by xnview »
Thanks to your detailed description I can reproduce
the problem.
Post
by xnview »
This problem is supposed to be fixed in
XnView MP 1.5.0 beta. Please check and confirm the bug fix here.
Post
by user0 »
fixed in 1.5.0
