Settings - view - info - rearrange controls
XnViewMP 1.4.5 64bit
Settings - View - Info
controls looks a little bit unpolished
  • frame
    - remove "Information displayed" frame around all controls as there are no any other functionality on this tab
  • change defaults
    - text color - white
    - background - black, opacity - 50% (transparent black looks much better than white)
  • "HTML tags supported" checkbox
    - rename to "Support HTML tags"
    - invoke Info rerender in Viewer on checkbox state change (the same behavior all other controls have)
  • reposition controls
    - Text settings (font, color, etc) shall go before Background settings (color). Its better to change it everywhere in app.
    - font name shall go first (so text/background colors can be placed close to each other)
Related
Re: Settings - view - rearrange Info controls
done in 160
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
