XnviewMP preview window blank
dm232
Post by dm232 »
In one of my windows 10 machine it is working fine. In another Windows 10 machine the preview window is always blank. Cant figure out what I need to change. Have latest release.
Correction: I noticed the same problem in other machine. Both were updated recently. The other machine was working fine before the update. I just did not check after the update. May be a problem with the latest version?
BTW xnview classic preview works fine
Thank you
d
dm232
Re: XnviewMP preview window blank
Post by dm232 »
ok found something. I went backward successively with previous versions, until it worked with 0.99.6. Then strangely enough when I installed the latest version on top of that it worked fine. No idea why. :shock:
with 1.4.5? could you send me the xnview.ini?
dm232
Post by dm232 »
Yes 1.4.5. I went through same experience on. my 3rd windows machine last night. Where do i look for this file?
Thanks Pierre
deep
Settings>Interface - Paths - Open config file
