Settings - unify ui of Toolbar, Shortcuts, Context menu tabs
XnViewMP 1.4.5 64bit
Settings - Interface
UI of Toolbar Shortcuts Context menu tabs is slightly inconsistant
unify ui of toolbar shortcuts context menu tabs
Mockup A
  • toolbar
    - add Filter
    - move Load/Save to the Default buttons
  • context menu
    - add Filter
  • shortcuts
    - add Filter
    - add header to the list, so it will be possible to sort items
Mockup B
  • toolbar
    - add Filter
    - swap lists
  • context menu
    - add Filter
    - swap lists
  • shortcuts
    - add Filter
Re: Settings - unify ui of Toolbar, Shortcuts, Context menu tabs
done in 1.5.0
but imho Mockup B has better elements alignment for Toolbar and Context menu tabs
also need to bring consistancy into naming: Default or Defaults
Mockup B shows 'filter' above the second list, but it filters the first one
but lists are swapped in Mockup B for Toolbar / Context menu tabs:
left (orange) - current controls
right (blue) - all available controls
Right, will be fixed in b2
fixed in 1.5.0b2
but I'm still not sure why button name differs:
- 'Default' - in Context menu
- 'Defaults' (plural) - in Toolbar, Shortcuts
