B3: Batch Convert: Remove "Remove all" button
Locked
In topic b1: Batch Convert - wrong placement of options various things regarding Batch convert dialog have been discussed.
I still think that the button "Remove all" should be removed. There's no real need for it.
The "-->" button (for adding transformations) should be renamed to "Add" (the complement to "Remove").
We could add a small arrow ">" to the buttons' labels:
Add >
< Remove
Re: B3: Batch Convert: Remove "Remove all" button
helmut wrote:In topic b1: Batch Convert - wrong placement of options various things regarding Batch convert dialog have been discussed.
Add >
< Remove
Yes right
Xyzzy
Post by Xyzzy »
confirmed in b3 and fixed in rc1.
X.
Locked
