1.5.0 - draw - move - stops working
XnViewMP 1.5.0b1 64bit
Draw - move
few issues with move action
2. open any image
3. press SHIFT+D to open Draw
4. scroll to zoom-in, eg to 400%
Issue A1
5. right click on image, hold and start moving
- hand cursor will appear
- viewing area will jump to the top of the image
- it only possible to move image ~10-20px in each side
Issue A2
6. zoom-in max to 1600%
7. right click on image, hold and start moving
- not possible to move image at all
Issue B
5. select Eyedropper
6. right click on image, hold and start moving
- hand cursor will appear for a split of the second and change to Eyedropper
Re: 1.5.0 - draw - move - stops working
will be fixed in b2
1.5.0b2
A1- fixed
A2 - fixed
B - still remain. I doubt this is feature as cursor changes to hand (while dragging) with all other tools.
user0 wrote: Sun Jun 18, 2023 6:57 am
Issue B
will be fixed in b3
user0 wrote: Wed Jun 21, 2023 3:25 am B - still remain. I doubt this is feature as cursor changes to hand (while dragging) with all other tools.
Is it fixed in beta3?
fixed in 1.5.0b3
