1.4.5 - app ui - fix progress dialog
XnViewMP 1.4.5 64bit
App UI - Progress dialog
same issues as in 1.4.5 - settings - catalog - fix Build thumbnails dialog
appears in few other places:
  • Create contact sheet
    - when switched to Preview tab
    - when pressed Create button
  • Settings - Catalog
    - when importing via "Import folder..."
  • I'm pretty sure there are a lot more places where this popup appears
Re: 1.5.0 - settings - catalog - fix dialog "Building catalog entries"
Is it a new issue of 1.5.0 beta?
same issue in 1.4.5
I have updated post with details
do you have always the issue in 1.5.5?
Re: 1.4.5 - app ui - fix progress dialog
yep, 100% reproducibility
160b
fixed in
- Create contact sheet
remain in
- Settings > Catalog > Import folder...
user0 wrote: Thu Sep 28, 2023 6:37 pm remain in
right
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
fixed in 160
