Is it possible to customize the info text in the new compare tool? Maybe it would be nice or a suggestion for for the next or major release.
Can you change the order of the text informations?
I would sort them this way:
1. filename with extension (e.g. Berlin.png - if you compare different files with same name, but different formats)
2. The long extension information is a little bit wast of space - Filesize and Pixelsize is good!
3. What does the () () () mean? Do they show EXIF/meta data, which are missing in my file?
4. The same as in line 4
5. The free line I would use for the CRC calculation
Fixed - 1.50 Beta #2 - compare tool - customization of the info text possible - other order of the text
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.50 Beta #2 - compare tool - customization of the info text possible - other order of the text
yes please a suggestion
Thank you user0 for your example.
I will try them.
I will try them.
