1.5.0 - viewer - edit comment - image reloads once dialog closed
XnViewMP 1.5.0b2 64bit
Viewer - edit comment
image reloads once 'Edit comment' dialog closed
2. open any image
3. press CTRL+D to open 'Edit comment'
4. press ESC to close it
image will be reloaded
if you modify image before opening 'Edit comment' dialog - Save As dialog will popup
Re: 1.5.0 - viewer - edit comment - image reloads once dialog closed
Is it a new issue of 1.5.0 beta?
same issue in 1.4.5
fixed in 160
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
