1.5.0 b2 Thumbnail getting regenerated again.
FKCapitalism2
Post by FKCapitalism2 »
Below is done using XnView MP interface.
Scenario 1 (proper operation):
I have image in the folder "One" (thumbnails already generated for images), then i create new folder "MyGallery" and move folder "One" into "MyGallery" by cut (Ctrl+X) and paste (Ctrl+V).
In this case XnViewMP updates catalog so thumbnails and does not re-regenerate thumbnails for images when i navigate to folder "One".
Scenario 2 (bug):
I have image in the folder "One" (thumbnails already generated for images), then i create new folder "MyGallery" and move image files from within folder "One" into my "MyGallery" by cut (Ctrl+X) and paste (Ctrl+V).
In this case XnViewMP DOES NOT updates catalog, so thumbnails for images need to regenerate again.
Scenario 3 (bug):
My catalog has been deleted completely.
I have folders with images "One" and "Two" as sub-folders to "MyGallery" folder, i navigate to folder MyGallery and go to menu View > Show files in subfolders, after this all images from folder One and Two show and thumbnails generate for them.
After all thumbnails generated i go to menu View > Show files in subfolders to uncheck this option and then i navigate to folder "One" or "Two" and thumbnails are starting to get re-generated again.
P.S. in 3rd scenario for folders with exclusively host video files no re-generation of thumbnails followed.
Re: 1.5.0 b2 Thumbnail getting regenerated again.
is it new bug in b2?
FKCapitalism2
xnview wrote: Wed Jun 21, 2023 11:29 am is it new bug in b2?
Scenario 2 is new bug for v1.5.0 B2
Scenario 3 i believe was already in v1.4.5
FKCapitalism2 wrote: Wed Jun 21, 2023 1:40 pm Scenario 2 is new bug for v1.5.0 B2
I can't reproduce, it works always
FKCapitalism2
xnview wrote: Wed Jun 21, 2023 1:56 pm
I installed clean v1.5.0 B2 and with fresh xnviewmp and i am getting bug described in Scenario #2.
Perhaps try with this ARW files https://www.upload.ee/files/15363912/ARW.zip.html
P.S. How about Scenario #3 can you reproduce that? Should i post it as new bug report for v1.4.5?
i've tried but can't reproduce screen
