1. Select some files
2. Select Copy to ... in context menu
3. Create a new folder
4. Enter the name (test1)
XnViewMP creates the folder. Here it would be very nice, if XnviewMP opens the new folder automatically and add the new folder to the Path field.
Fixed - New Move/copy files dialog - create folder - behaviour
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: New Move/copy files dialog - create folder - behaviour
Thank you for fixing it!
I am sorry, but the checkbox "Show selected folder tree" does not do anything.
If I create a new folder, I expected to see a highlighted folder in the tree structure.
But nothing happened.
No, it's only to expand folder tree with last folder when opening dialogmasterjp wrote: Tue Jun 27, 2023 4:08 pm I am sorry, but the checkbox "Show selected folder tree" does not do anything.
Okay, everything is fine.
