1.5.0 - compare - few issues
XnViewMP 1.5.0b3 64bit
Compare
1. run clean portable XnViewMP in Browser mode
2. open Compare tool
Issue A
3. resize app window
A/B separator will go offscreen
Issue B
3. click on any 3 thumbnails in toolbar below
sometimes, maybe depends on image dimentions
- view selector will jump to Normal, A/B become disabled
- left image does not update until A/B slider is moved OR focus switched from Compare dialog to any other window
masterjp
Re: 1.5.0 - compare - few issues
Post by masterjp »
I can confirm Issue A under Windows 10.
Issue B
Please check the height and width of the pictures you use.
If the sizes are different, a/b mode will be disabled.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
masterjp wrote: Thu Jun 22, 2023 8:00 pm Issue B
yeah, the only problem - xnview loads new image into left (or right, depends on selection) part of A/B instead of swiching to Normal comparing mode
imho, there shall be advanved mode where you can load images of different sizes into A/B, but there shall be ability to:
- unlink them to reposition smaller image via combobox into ⠇⠇⠇or manually
- disable Best fit auto-zoom
will be fixed in b4
please check b4
1.5.0b4
A - still remain
B - fixed
C - when you are in A/B
- select any number of images except 2
radio button shall switch to normal and A/B became disabled
right will be fixed
all fixed in 1.5.0
