1.50 beta #3 - zip file - 'Open with' does not work
masterjp
Post by masterjp »
I have a zip file, which contains different jpeg files.
I can open the zip file within the thumbnail browser window and view every single jpeg file.
If I want to use the 'open with' function from context menu, the linked program starts, but did not open the picture file.
I have photoshop elements 2023 in my list of 'open with' programs. Picture files work perfect, but not from an archiv file.
Is it possible to fix it? Thank you.
Re: 1.50 beta #3 - zip file - 'Open with' does not work
same in 1.4.5?
masterjp
Post by masterjp »
Version 1.4.5 has the same problem with opening jpg files from zip archiv.
