Moderators: helmut , xnview , Dreamer
Posts: 2664 Joined: Sat May 09, 2015 9:37 am
Post
by user0 » Tue Jun 27, 2023 5:15 am
XnViewMP 1.5.0b3 64bit
Draw - watermark
wrong selection when resizing to 1x1
2. open any image in Draw
3. add any watermark
- select top-left corner
- start dragging to bottom-right corner
when corners met and image fliped
issue A
selection/image will be out of sync
issue B
image will increase in size
ps. no issue in 1.4.5
Related
user0 on Thu Oct 12, 2023 1:22 pm, edited 3 times in total.
Posts: 47034 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Wed Jun 28, 2023 1:00 pm
you have not this issue in 1.4.5?
Post
by user0 » Wed Jun 28, 2023 1:18 pm
user0 wrote: Tue Jun 27, 2023 5:15 am
Post
by xnview » Wed Jun 28, 2023 1:25 pm
user0 wrote: Wed Jun 28, 2023 1:18 pm
i have the same in 1.4.5 & 1.5.0
Post
by user0 » Wed Jun 28, 2023 1:37 pm
you are right, issue existis in 1.4.5 as well
Post
by xnview » Wed Sep 27, 2023 12:44 pm
Thanks to your detailed description I can reproduce
the problem .
Post
by user0 » Fri Sep 29, 2023 7:49 am
fixed in 160
however, I think its better to
- mirror image when you drag side point over opposite one
- inverse (mirror both sides) when you drag corner point over opposite one
Post
by xnview » Thu Oct 12, 2023 1:10 pm
This problem is supposed to be fixed in
XnView MP 1.6.0 . Please check and confirm the bug fix here.
