Stop canceling name change when an item is blocked by another process
The Electro Machine
Post by The Electro Machine »
If user attempts to change name of file or folder that is being used by some other process then a pop-up window will appear saying
An error occurred during renaming!
and bearing only the OK button. This should not be like so as it is counterproductive- and the more the longer and more sophisticated name was user wants to apply
Hence users should be given ability to click something like Retry button in that box, i.e. be able to address resolving of such blockade outside of XnViewMP and then coming back to it and performing a quick retrying of name change without a need to write it once more from scratch
