1.4.5 - viewer - error renaming video
XnViewMP 1.4.5-1.5.0b4 64bit
Viewer
2. open .webm
3. press F2 to rename
- rename
- press OK
error message will appear "An error occured during renaming"
Re: 1.4.5 - viewer - error renaming video
do you have same problem for mp4?
yes
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
issue remains
do you pause the video file?
issue does not depend on playback state, video can be paused or playing
browser is not opened?
yep,
  • error
    - if video file opened from brower tab
  • no error
    - if opened via other ways
    - also no error if opened from browser, but navigated to another folder
ok, if the video file is locked in browser, it can't be renamed in viewer
btw, same issue with .mp3
