The program takes a long time to open "heavy" GIFs (30-100 MB) - in comparison with some analog programs, even the simplest ones. Test when opening from the Explorer (context menu commands "Send" or "Open with..."):
Imagine - almost instantly
qimgv - instantly
ACDSee 2.41 - instantly
XnViewMP - delay (the cursor changes to a rotating indicator - "busy") up to 3 seconds! When opening files from the internal browser, the same delay is observed.
It seems to me that this is some kind of bug. If programs with a size of 1.5 mb correctly open "heavy" GIF instantly, then why such a powerful advanced viewer as XnViewMP can't do this?
I tested the most recent version, but on previous problems the same.
PS
GIF for testing can be taken here:
https://files.fm/f/4zcx84q2s
or here:
https://commons.wikimedia.org/wiki/Cate ... and_100_MP
1.5.0 beta 4 - Long opens "heavy" GIF
adrem85
Re: 1.5.0 b4 - Long opens "heavy" GIF
Currently XnView loads all frames before to display...
adrem85
Thank you, the reason seems clear. And is it possible to make the viewing start immediately, as in the above-mentioned viewers? There are a very large number of frames in "heavy" GIFs and this causes a noticeable delay when opening them even on the powerful computer (Windows 11, fast memory, processor and motherboard of the latest generation, SSD).
