b3: [bug] no update after renaming
Locked
FlorianH
Post by FlorianH »
a) rename folder in browser...
  1. create folder with subfolders
  2. open [+] folder in treeview, so that subfolders are visible
  3. rename subfolder in file list -> treeview is not updated
  4. select renamed subfolder in treeview (old name) -> xnview crashes
But if you rename a folder in windows explorer while xnview is open and folder is visible in treeview, treeview is updated automatically -> very good.
b) rename file in browser file list...
  1. open image in viewer -> keep viewer tab open
  2. go to browser and rename image -> viewer tab is not updated (tab caption and information string)
Same here with windows explorer. If i rename a file in windows explorer, xnview browser file list is updated, but xnview viewer tab is not.
Xyzzy
Post by Xyzzy »
Both confirmed in b3.
X.
Re: b3: [bug] no update after renaming
FlorianH wrote:a) rename folder in browser...
ok
Yes normal, when a picture is opened i don't check if file is always here after, it's for me a normal behaviour.
FlorianH
Post by FlorianH »
a) is fixed in rc1
b) i think pierre didn't want to fix (i think he should)
What do other users think about case b) described above?
Xyzzy
Post by Xyzzy »
as for b) I think we can consider View as snapshot of file at some moment in time, so that when you delete the file or rename it in Browser, View still keeps the state.
Fixed for me.
If you think it should be updated neverthless, post a Suggestion. But please, don't think only about filename, but rather about the whole idea behind it and its consequences.
X.
Locked
