1.5.0 beta 4 - WEBP-animation doesn't work
adrem85
Post by adrem85 »
Shows only the first frame. If you turn on the "playback panel", then clicking on the "start"/"pause" button does not give anything. The other animation (GIF/APNG/JXL) works fine.
Also, there is no transition to the next/previous file when using the mouse wheel. It seems that the program "freezes".
At the same time, version 1.4.5 works fine. Windows 11.
Re: 1.5.0 beta 4 - WEBP-animation doesn't work
right will be fixed in final version
adrem85
Post by adrem85 »
xnview wrote: Thu Jul 06, 2023 7:13 am right will be fixed in final version
Fixed in 1.5.0, thanks!
