Adding "YYYY/YYYY_MM" to "Import and sort" as Subfolder
TobiWanKen0bi
Post by TobiWanKen0bi »
Hi XnView Team,
first of all you XnView is by far my favorite software to organize my Photos.
I lately got a DJI and no I try to automate the image import from the SD card.
I would love to have another sub folder option in the "Import and sort" Tool.
Would it be possible to add "YYYY/YYYY_MM" to the list. This way I don't need extra software and I can stay fully in XnViewMP.
THAT WOULD BE SUPER NICE
Thanks for all the great work!!!
Tobi
TobiWanKen0bi
Re: Adding "YYYY/YYYY_MM" to "Import and sort" as Subfolder
Oh and it would be super nice to have the option to add a categories to "Import and sort". This way I can select some categories and they automatically get assigned to the fotos when they get copied over
thx
tobi
Post by michel038 »
Locate your xnview.ini file with Settings>Integration>Paths (and use "Open config files location" button)
Edit xnview.ini in a notepad, search for yyyy , so you can find the list subFolder= with all formats. Add yyyy/yyyy_MM (comma and space separators)
Save, and restart Xnviewmp ...
And in Import and Sort dialog, "Categories to assign" is already there ...
TobiWanKen0bi
Thanks for the fast answer and sorry for me being blind on the categories :(
