sort issue on "fabricant" and "modele" (manufacturer-model)
GLE
Post by GLE »
Hi
(Sorry for my poor english).
Sort is not working correctly as you can see in the attachment (in this case it was on "modele" field)
Same issue on "manufaturer" field.
XnView MP Windows
Version 1.4.5 64bits (May 10 2023)
Best regards
Ps. can we report issues in french ?
sort result on "model" field.
Re: sort issue on "fabricant" and "modele" (manufacturer-model)
please check the 1.5.0
GLE
Post by GLE »
Hi Pierre
Thks for your prompt answer.
Understood that this will be implemented into the 1.5.0 version ?
Best regards
it was an issue of 1.4.5
GLE
Post by GLE »
Ok Pierre
But in that case what means your wordings : "please check the 1.5.0"
Best regards
Franky
Post by Franky »
The V1.5 has just been released, you can check if the problem is solved.
GLE
Post by GLE »
this is what I extrapolate originally from your msg but fyi, this version is not yet available from your site (just checked again now)
I will keep you informed
Best regards
its available on forum:
viewtopic.php?f=82&t=45663
GLE
Post by GLE »
Hi Pierre
It's OK
Thank you very much
Have a good day
Guy
