After setting a category in a webp format file and copying it to another directory using windows explorer, the category data is gone.
The same operation jpg is no problem.
XnViewMP version is 1.5.0.
Unable to write category data into webp format file
ddvc
Re: Unable to write category data into webp format file
and no problem with 1.4.5?
ddvc
Version 1.4.5 also has this problem
do you write category in embedded metadata?
ddvc
What is embedded metadata?
Is that mean .xmp file ?
I did't create .xmp files to save metadata.
JPG can write metadata into the JPG file.
I think writing metadata to the file is very cool.
Is that possible to write metadata into WEBP files?
What do you have in Settings>Metadata
yesIs that possible to write metadata into WEBP files?
ddvc
xnview wrote: Wed Jul 12, 2023 8:31 amWhat do you have in Settings>Metadata
Sorry i'm wrong. WebP support XMP categories when you convert from jpeg/PNG for example, but you can't directly change XMP categories into WebP files. Only support sidecar...
ddvc
Thank you for your answer, I hope support writing category to webp files ASAP.xnview wrote: Wed Jul 12, 2023 11:17 am Sorry i'm wrong. WebP support XMP categories when you convert from jpeg/PNG for example, but you can't directly change XMP categories into WebP files. Only support sidecar...
rafrafraf
Hello, I use webp a lot, and need to use categories metadata. Is there possibly a roadmap to add `write to file` metadata/xmp for WEBP? This would be a boon. Thank you
