toolbar icon GUI / toolbar icon file(s) ("foo.bar" and "default.bar") - corrupted
Gerald_Ire
Post by Gerald_Ire »
Subject: 1.5.0: toolbar icon GUI / toolsbar icon file(s) (own "foo.bar" / "default.bar") - after update from 1.4.5. to 1.5.0 - corrupted
XnView: MP 1.5.0 64 bit
OS: Windows / 64bit
Update from 1.4.5 to 1.5.0 changed toolbar icon gui and toobar files default.bar/foo.bar
Effect: more "space lines", icon order, some icon are missing now / so far no crashing
shows "View" (old/new)
shows "Browser" (old/new)
Quick fix: copy the old toolbar icon file(s) ("foo.bar" and "default.bar") in your appdata/roaming/xnviewmp/...
1. download version 1.5.0
2. update 1.4.5 to 1.5.0
3. after that/next day - not sure
4. toolbar icons changed in "browser mode" and "view mode"
5. toolbar files "default.bar" and "foo.bar" changed (appdata/roaming/xnviewmp/...)
Actual behaviour (bug): toolbar gui and toolbar files are corrupted :bug:
Expected behaviour: toolbar gui and toolbar files are the same as 1.4.5
:D Gerald says thx to all! :D
Re: toolbar icon GUI / toolbar icon file(s) ("foo.bar" and "default.bar") - corrupted
could you send me your own .bar?
1. goto Settings > Toolbar
issue A
2. switch to Viewer
- press "Defaults" button
- press OK to save settings
Viewer's toolbar will be messed
pressing "Defaults" button when Browser is selected fixes the issue
issue B
2. switch to Browser
Browser's toolbar will be messed
pressing "Defaults" button when Viewer is selected fixes the issue
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
fixed in 1.5.1
Gerald_Ire
It works now!
Startet 1.4.5 with AppData-setup...
Installed 1.5.1 and checked Tools/Settings/Interface/... and "played" with "Default"... "Load" ... (own) foo.bar ... and it works!
Merci beaucoup!
