1.5.0 - settings - toolbar - Set Icon... button has no label when custom command is selected
XnViewMP 1.5.0 64bit
Settings - toolbar
Re: 1.5.0 - settings - toolbar - Set Icon... button has no label when custom command is selected
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
issue remains
Issue B
1. add new Command button
2. set icon to this button
- press OK
full path will be inserted into its label
Issue C
1. set new icon to default button, eg About
- press OK
icon will be changed
2. goto Settings > Interface > Toolbar
- press Default
icon will revert to default in Settings
- press OK
icon will not revert to default in Toolbar untill restart
issue reopened
Issue C: Yes, XnView need to be restarted in this case...
xnview wrote: Thu Jul 20, 2023 6:58 am Issue C: Yes, XnView need to be restarted in this case...
it just feels inconsistent as custom icon applies immediately, but its required restart to revert to default
This problem is supposed to be fixed in XnView MP 1.5.2. Please check and confirm the bug fix here.
B - fixed
152-170
Issue D
  • D1 – label positioning
    label horizontal positioning should not depend on icon size
    try to assign test images as icons
    icons_img.zip
  • D2 – 'Set icon...' button label
    'Set icon...' button has no label when custom command is selected (see pic, Riot is selected)
  • rework 'Set icon...' button
    - (done) do not show current icon on this button as it is useless information
    - if custom command already has icon - change button name to 'Remove icon'
Last bumped by user0 on Fri Mar 29, 2024 7:53 am.
