Is there a way to improve the parsing and loading speed of HEIF (High Efficiency Image Format) files, specifically those
Atlas5215
Post by Atlas5215 »
In my case, XnView takes approximately 2 seconds to display the HIF file taken by Sony A7M4, while the ARW file loads smoothly. Thank you for your hard work!
Here is the Sony HIF file:
https://github.com/drewnoakes/metadata- ... aster/heif
By the way, my PC configuration includes an R7 7700X processor, RX7900XTX GPU, 64GB DDR5 RAM, and a 2TB M2 NVME drive.
I hope this helps!
