Hi again,
I like renaming with xnView. Even non-image files. Mostly because of the list below where you can check every file.
But if there were the possibility to add more replace operations (and other modification options), you could to more in one step.
The best option would be a java script renaming feature. So a little coding field and a small console next to it. You would get the file name, extension and a reasonable amount of metadata in a js-object. And then you can manipulate it in any way your script kiddy heart can imagine and output it to your batch list.
Just dreaming...
Have an awesome day,
kws
More renaming options (Maybe using a java script? 😬 )
kweso
