Shortcut (keyboard) rotation on browser
ashkir
Post by ashkir »
Hello. From looking at the settings it looks like there was some sort of rotation support for shortcuts on the browser.:
However, the buttons under the browser window do work:
I tried all the combinations in the shortcut. None of them seem to rotate the thumbnail (and whole image) short of me having to actually click the rotate buttons, or opening the image and rotating it there through the shortcuts.
Am I missing something?
Re: Shortcut (keyboard) rotation on browser
I've tried to add shortcut for example to cmd_rotate180, and it works correctly
ashkir
Post by ashkir »
xnview wrote: Fri Jul 14, 2023 7:19 am I've tried to add shortcut for example to cmd_rotate180, and it works correctly
We just tried the cmd_rotate90 no effect on browser via shortcuts. Same for cmd_lrotate90. Tried the cmd_rotate270, cmd_lrotate270 as well.
However the cmd_rotate 180 does work perfectly fine in Windows 11.
Is there anything I'm missing for the 90 degree rotations?
Thank you for your time!!
ashkir
Post by ashkir »
installed on a Windows 10 machine it works. Seems to be a windows 11 thing!
Thank you! I got it working now
I have no issues with these rotation Shortcuts in Win11
it works as expected for JPEG
maybe you are trying to rotate unsupported files,
eg lrotate - lossless rotate, for JPEG only
ashkir
Post by ashkir »
I wonder if it just doens't work with Tifs? The shortcode for cmd_rotate180 and cmd_rotate90 work. But I can't get cmd_rotate270 to work.
