Browser - filelist - rename - incorrect cursor position
XnViewMP 1.5.0
Browser - filelist - file rename
incorrect cursor position after selection is cancelled
1. open Browser
2. select image
3. press F2 to rename
whole name will be selected
Issue A
4. press → once
selection will be cancelled
cursor will be positioned one character to the right after selection
Expected behaviour
arrows in rename mode shall work the same way as in Windows File Explorer:
cursor shall be positioned right after last character of the selection
Issue B
same issue if rename via popup dialog (in Browser/Viewer)
4. manually select few characters in the middle of the name
5. press → (or ←) once
cursor will be positioned to the wrong place that for some reason based on the direction of selection
Expected behaviour
→ - cursor shall be positioned right after last character of the selection
← - cursor shall be positioned right before first character of the selection (same as in issue A)
Issue C
4. press ↑ or ↓ once
name edit mode will be cancelled
focus will shift to another file
Expected behaviour
↑ equals ←
↓ equals →
Related
vertigo
Re: Browser - filelist - rename - incorrect cursor position
Post by vertigo »
Bumping this as this issues has now gone 2.5 years unresolved and without response since posted, and my post a year ago regarding it also didn't get an admin response. This seems like it should be a relatively minor fix, yet it's a major issue for actual use and is the main reason I've never really switched to using XnView, even though it would be preferable otherwise. I'd appreciate some discussion either regarding the intent to fix this or reasoning to not do so, as I'm hoping it can be done so I can use XnView more, but would really like to at least know if there's no intention of doing so, so I can figure something else out.
it's not better to go before dot?
xnview wrote: Sat Dec 13, 2025 12:43 pm it's not better to go before dot?
nope
need to mimic exact behavior of win file explorer in basic functionality, as it is practically the standard
