Settings - filelist - custom filter - open with
double-click action's dropdown in Custom filter does not contain all 'Open with' options, which is inconvenient [1]
- add more 'Open with' options for double-click action
- add 'Associated editor'
- add all User commands
Related
- issues
1.9.2 - browser - filelist - addressbar and titlebar when opening file list
1.7.1 - browser - filelist - header highlighting issues
- todo -
1.9.3 - browser - filelist - no update after lossless operations
1.9.2 - browser - filelist - misleading Folder conflict dialog when copying shortcut
- fixed -
1.11.2 - settings - browser - columns - date duplicated (1.11.4)
1.11.1 - browser - filelist - details view - row stretch (1.11.4)
1.10.5 - browser - filelist - disabled 'Select none' (1.11.1)
1.8.0 - browser - filelist - details view - pasted file opens in new instance (1.9.0)
1.6.5 - browser - filelist - history is purged only when Browser tab is opened (1.8.1)
1.7.2 - browser - filelist - checkbox looks checked at win scale >100% (1.8.0)
- suggestions
Browser - filelist - sort - improve naming
Browser - filelist - sort - improve order for folder shortcuts
Settings - filelist - custom filter - open with - add more options (current post)
Browser - filelist - filter - improve tags
Browser - filelist - toolbar - improve customization
Browser - filelist - toolbar - rework filters
Browser - filelist - hint - limit max length
- done -
Browser - filelist - rename - incorrect cursor position (1.9.9)
Browser - filelist - Move should not Copy files (1.9.6)
Browser - filelist - Copy should not be default action (1.9.6)
Browser - filelist - add statusbar (1.9.0)
Browser - filelist - details view - improve Rating, Color label appearance (1.8.1)
Browser - filelist - context menu - unify behavior (1.8.0)
