Browser - filelist
issues with addressbar and titlebar when opening file list
1. have txt file with few fullpaths to images and empty lines
2. drag&drop txt on xnviewmp.exe
issue A
filelist will be opened, but address bar will be empty
expected behaviour
address bar to show <files>, as it indicates when txt is opened via 'Open file list...' command
issue B
app titlebar will show :misc
expected behaviour
maybe it should be :files or :filelist ?
issue C
empty lines show as 'drive' icon
expected behaviour
ignore empty lines
Related
- issues
1.9.2 - browser - filelist - addressbar and titlebar when opening file list (current post)
1.7.1 - browser - filelist - header highlighting issues
- todo -
1.9.3 - browser - filelist - no update after lossless operations
1.9.2 - browser - filelist - misleading Folder conflict dialog when copying shortcut
- fixed -
1.11.2 - settings - browser - columns - date duplicated (1.11.4)
1.11.1 - browser - filelist - details view - row stretch (1.11.4)
1.10.5 - browser - filelist - disabled 'Select none' (1.11.1)
1.8.0 - browser - filelist - details view - pasted file opens in new instance (1.9.0)
1.6.5 - browser - filelist - history is purged only when Browser tab is opened (1.8.1)
1.7.2 - browser - filelist - checkbox looks checked at win scale >100% (1.8.0)
- suggestions
Browser - filelist - columns - update date labels
Browser - filelist - sort - improve method naming
Browser - filelist - sort - improve order for folder shortcuts
Settings - filelist - custom filter - open with - add more options
Browser - filelist - filter - improve tags
Browser - filelist - toolbar - improve customization
Browser - filelist - toolbar - rework filters
Browser - filelist - hint - limit max length
- done -
Browser - filelist - rename - incorrect cursor position (1.9.9)
Browser - filelist - Move should not Copy files (1.9.6)
Browser - filelist - Copy should not be default action (1.9.6)
Browser - filelist - add statusbar (1.9.0)
Browser - filelist - details view - improve Rating, Color label appearance (1.8.1)
Browser - filelist - context menu - unify behavior (1.8.0)
