1.5.0: Ratings and labels lost when moving files
Devan22
Post by Devan22 »
XnView: MP 1.5.0 - 64 bit
OS: Windows 11 64bit
Ratings and labels are lost when moving a file containing them to a different folder. This via context menu > "move to..." or by cutting/copying/pasting it.
Effect: Ratings and labels are lost. Dragging the file into a folder still works somehow. It only affects ratings and labels so far, categories and tags are still preserved. This bug happened as soon as I updated to 1.5.0.
Method 1:
1. Assign a rating or a label to a file.
2. Cut or copy the file within the program.
3. Paste it into a different folder.
Method 2:
2. Open context menu with right click.
3. Select "Move to..."
4. Choose any folder different than the current one.
Actual behaviour (bug): The file in the new location will lose it's ratings and/or labels.
Expected behaviour: Ratings and labels should remain, as it was in the previous versions.
Re: 1.5.0: Ratings and labels lost when moving files
what do you have in Settings>Metadata?
Devan22
Post by Devan22 »
I believe everything is set to default. Both "Export rating in XMP metadata" and "Export color label in XMP metadata" are unchecked.
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
Devan22
Post by Devan22 »
It is fixed now.
