Segmentation fault (core dumped) when viewing a .HEIC file
theorin
Post by theorin »
I am trying to run .tgz installation on almalinux in order to get support for .heic files as oposed to flatpak installation I have been using up until now.
XnView starts and runs normally, however when opening a folder with .heic files, XnView crashes.
This is my terminal output:
## onItemPressed
setPathname </run/media/martin/DATA_3T/PHOTO/iPhone/>
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: setFileList(0)
 ** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 3a77a30
CHECK <0>
######ThumbLoaderThread :: forever : 3a77a30
 ** start condition wait
## OPEN FOLDER
## Check folder
  ## Check companion  0
  ## Check companion ok  0
  ## OPEN DB FOLDER ok  0
  ## UPDATE DB FOLDER ok  0
  ## OPEN FOLDER ok  0
## updateLabel  0
## updateLabels ok  0
######### CategoryModel :: checkAndSave()
SORT the list...
STD::SORT... 0
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
BitmapLoadThread :: stop()
Create children /run/media/martin/DATA_3T/PHOTO/iPhone/
## OPEN FOLDER done  1
### ThumbLoaderThread :: setFileList(20)
CHECK <19>
sizeHints : 241
### START 20
######ThumbLoaderThread :: start : 19     -1 -1
sizeHints : 241
 CHECK : <IMG_7001.HEIC>
LOAD BITMAP </run/media/martin/DATA_3T/PHOTO/iPhone/117APPLE/IMG_7001.HEIC>
Any ideas what might be the problem?
Re: Segmentation fault (core dumped) when viewing a .HEIC file
which libheif version do you have?
theorin
Post by theorin »
I have libheif version 1.7.0
please update to 1.12.0+
theorin
Post by theorin »
I am afraid there is no repository providing higher version than 1.7.0 for any RHEL 8 distribution.
I can try to install it manually from a Fedora .rpm file and see how that goes. I am just not sure if it's a good idea. :?
theorin
Post by theorin »
Manual installation didn't go through.
I tried copying libheif.so.1.16.2 directly to the XnView/lib folder and creatinf simlinks libheif.so and libheif.so.1 within that folder as well.
Interestingly enough doing so removed the heic format from About/Formats. Without me removing libheif library from the system.
