Batch rename - add Error column
XnViewMP 1.5.0 64bit
Batch rename
there is no way to check if all files will be renamed witout issues beforehand
add Error (Status) column
that indicates if there are any issues with renaming sequence (or file access)
UI examples
  • Advanced Renamer
  • ReNamer
Re: Batch rename - add Error column
it should not happened, because if same new names, duplicate settings is used
