Title bar not updated when switching between tabs
AndreasW
Post by AndreasW »
Using XnView MP 1.5.0 on iMac with Intel processor.
When you open more than one image in the viewer and then switch between tabs, the file name (or other information) in the title bar of the program window will not be updated accordingly.
I consider this a bug. If it is not, then please move this topic to Suggestions.
Re: Title bar not updated when switching between tabs
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
AndreasW
Post by AndreasW »
The problem is fixed in v1.5.1. Thank you very much!
