The command line gets broken at spaces and the target application can not find the file.
If the file path does not contain spaces, "Open With ..." functions perfectly.
"Open With ..." not working in version 1.5.0
Re: "Open With ..." not working in version 1.5.0
on Windows? Do you use arguments?
This problem is supposed to be fixed in XnView MP 1.5.1. Please check and confirm the bug fix here.
