It is suggested to add mozjpeg format for batch conversion.
I need to compress the pictures in the PDF file, but the PDF file does not support the latest webp, jxl, heif, avif and other formats. It is a good choice that mozjpeg is perfectly compatible.
Re: It is suggested to add mozjpeg format for batch conversion.
Guetzli is not very easy to use
