MP1.5: After customizing the toolbar, the number of useless separators will continue to increase
bsty2k
Post by bsty2k »
Subject: MP1.5: After customizing the toolbar, the number of useless separators will continue to increase.
XnView: MP 1.5 - 64-bit
OS: Windows 10 - 64-bit
Effect: It looks ugly and it's troublesome to delete it manually.
1. Open a picture, in "viewer" mode, rightclick toolbar, choose "customize toolbar".
2. In the pop-up menu, even if you don't do anything, just click 'ok', there will be a bunch of separator bars on the far left of the toolbar in viewer mode. Clicking "Default" also has the same result.
3. Each time you repeat this, there will be an extra pile of separators. The number of separators will continue to increase.
4. Even if you save the layout of the toolbar first, it will increase the number of separators after loading.
5. It seems that every time you customize, all the buttons and separators on the toolbar are copied and pasted, but in fact, only the new separator bar is displayed on the toolbar.
6. Once you operate several times, if there are too many separators, manual deletion will be very troublesome, you can only click the mouse to delete one by one.
It's not a big problem, but I hope it will be resolved soon
Re: MP1.5: After customizing the toolbar, the number of useless separators will continue to increase
check 1.5.2 version
jonnydrummer
Post by jonnydrummer »
I'm having same issue on 1.5.2 - 64 bit
Also Windows 10 - 64 bit
i can't reproduce, please send me your default.bar?
