After installing and selecting run XnViewMP - I got a Error "Code 740"
Tried it twice, same error.
Maybe something to do with admin. rights?
Help about shows the right (updated) version though.
Install-Error-Code 740 (?)
mrwul
Re: Install-Error-Code 740 (?)
and you can start it correctly? do you had same thing on previous setup? Windows 11?
I can't reproduce on Windows 10
mrwul
This is on Windows 10 x64 19045.3208 (AFAIK the latest built).
This is the first time that I selected 'Run XnViewMP' immy after the install. Normally I leave that option remains deselected, as well as the option 'Visit website', i.e. both deselected and [Finish].
Regret I can't tell about previous versions.
XnViewMP launched from desktop icon works fine, as expected.
Double clicking an image file: XnViewMP launches without problems.
It is not a big thing, just reporting.
