since v. 1.5.0 - pressing home in fullscreen problem
vanderzee
Post by vanderzee »
since Version 1.5.0 64bits (Jul 10 2023) whenever viewing images fullscreen and pressing HOME, instead of going to the first image like in previous versions, now it goes to the very beginning over folders, so you have to scroll through severasl black screens to skip the folders to get to the first image
is there some way to fix this aside from downgrading to an older version?
thanks
Re: since v. 1.5.0 - pressing home in fullscreen problem
This problem is supposed to be fixed in XnView MP 1.5.3. Please check and confirm the bug fix here.
vanderzee
Post by vanderzee »
yes, now it is working as it should
thank you so much for fixing this so quickly :D
xnview wrote: Fri Aug 11, 2023 12:24 pm This problem is supposed to be fixed in XnView MP 1.5.3. Please check and confirm the bug fix here.
