Remove image from "album"
vegaa
Post by vegaa »
Sorry I posted on the wrong section before (Xnview classic). I copy my post here.
I'm new on this software. I'm using "albums" in "Filtre catégorie" (sorry I use the french version) and I can't find how to remove a picture from the album selection?
Can you please help?
Thanks.
Re: Remove image from "album"
Post by michel038 »
english/french
I looked for functions that might relate to the notion of albums, and didn't find much.
To add a photo to an album, I only saw that I could drag and drop it, otherwise there's the right-click to create, empty, rename, delete, import and export albums.
One technique is to export the album (which is a way of saving it), then open the .filelist file of the same name with a text editor (Notepad++) to edit it ... and re-import it. It's not an elegant method.
Nor have I been able to find a way of determining whether or not a photo belongs to an album.
Note: you can generate files of the same type (Adobe Bridge filelist) without using the album functions with the "Create > Filelist" function with the following parameters :
<file uri="bridge:fs:file://{Directory}{Filename With Ext}"/>
in text format
Next we need to change the first line of the resulting file:
<?xml version="1.0" encoding="UTF-8"?><arbitrary_collection version="1">
And the last line:
</arbitrary_collection>
J'ai cherché les fonctions qui pouvaient se rapporter à la notion d'albums, et pas trouvé grand chose.
Pour ajouter une photo à un album, j'ai seulement vu que je pouvais la glisser déposer, sinon il y a le clic bouton droit pour créer, vider, renommer, supprimer, importer, exporter des albums.
Une technique consiste à exporter l'album (ce qui constitue un moyen de le sauvegarder) , puis ouvrir le fichier .filelist du même nom avec un éditeur de texte (Notepad++) pour le retoucher ... et le ré-importer. Ce n'est pas élégant comme méthode.
Je n'ai pas pu trouver non plus un moyen de déterminer si une photo appartient ou non à un album.
Remarque : on peut générer des fichiers du même type (Adobe Bridge filelist) sans passer par les fonctions album dans XnViewMP, avec la fonction "Créer > Liste de fichiers" avec les paramètres suivants : (en ayant sélectionné les fichiers concernés au préalable)
au format texte
Ensuite dans le fichier obtenu il faut changer la première ligne :
Et la dernière ligne :
vegaa
Post by vegaa »
Merci beaucoup pour ta réponse.
Y aurait-il sous XnView une façon plus adaptée de faire des groupes de photos? Qui me permettrait d'en ajouter et d'en enlever?
Je ne suis pas très familier avec les imports/exports de liste mais je vais étudier ta proposition. Mais cela me parait trop rébarbatif pour que j'adopte à l'usage cette technique.
Il doit bien y avoir une façon de faire ...
Post by michel038 »
Ca dépend de la nature des groupes de photos...
Si ça peut correspondre à des catégories ou des mots-clés c'est simple, les catégories sont là pour ça.
On peut attribuer plusieurs catégories aux photos, et faire des combinaisons dans le filtre pour obtenir le résultat ex: vacances + poisson + Pierre
Mais ça doit être limité en nombre de catégories (il n'est pas judicieux de créer autant de catégories que d'évènements sportifs par exemple)
Personnellement, pour retrouver des évènements récurrents, je range mes photos dans des sous dossiers datés (D:\Photos\2022\2022-07-02 Vacances Pyrenees\
Et avec des mots clés (ou catégories) comme vacances, montagne, plage, camping .. j'arrive à obtenir ce que je souhaite en combinant les catégories et les années , mais il faut un peu d'habitude pour combiner des critères de différente nature.
Sinon, une bonne méthode c'est de créer des diaporamas et les enregistrer, ca crée des fichiers sld.
Après, avec le menus "Créer > Diaporama > Ouvrir ..." on peut le modifier dans le premier onglet.
On peut aussi imaginer ajouter une catégorie pour chaque année (2020, 2021, 2022 ...) mais c'est pas élégant, les dates sont déjà dans les (données exif des) photos, et XnViewMp pourrait évoluer dans le futur pour filtrer commodément les dates exif des photos ...
Il y a déjà eu des évolutions avec la gestion des personnes, mais pour le moment la reconnaissance des visages doit être faite avec d'autres logiciels.
vegaa
Post by vegaa »
Alors pour être plus précis, j'ai des milliers de photos que j'ai déjà classées (mots clés, notes) qui sont réparties dans divers dossier sur mon ordi.
Je veux faire une sélection de 30 photos pour les publier sur un thème donné. Je récupère les photos de mon thème, j'en ai disons 200. Je n'ai pas envie de modifier quoi que ce soit aux fichiers en question pour des usages ultérieurs. Par contre, j'aimerais en parcourant les 200 photos pouvoir faire ma sélection de 30 en les plaçant dans une liste gérée par le logiciel (je pensais que les albums étaient là pour ça). Je pourrais aussi utiliser une couleur puis ensuite l'enlever une fois ma sélection faite et le travail terminé (car ensuite je copie les fichiers pour les exporter en ligne).
Mes méthodes sont surement archaïque, je fais ce que je peux ...
Merci encore pour l'intérêt que tu portes à ma question !
Post by michel038 »
Oui, affecter une couleur c'est une bonne méthode. De même on peut affecter un "rating" avec étoiles, ou une "marque" avec Ctrl T
Les "marques" ont une gestion sympa Clic droit > Marque > (...)divers choix... (et aussi Paramètres>Explorateur>Marque)
Afficher les photos marquées parmi celles affichées, c'est moins évident
Il faut utiliser les en-têtes (Afficher >Trier les fichiers par > Voir l'en tête) pour classer par "marque" et les regrouper .
vegaa
Post by vegaa »
OK. Merci. Je vais me débrouiller !
