Drag and Drop in Ubuntu 23.04 not working
leunam12
Post by leunam12 »
Hi, I just installed Ubuntu 23.04 and XNView, but drag and drop doesn't work. Dragging from xnview to anywhere outside its own window, causes the Gnome Session to crash. Dragging from the main window to another folder in xnview simply shows a "No" icon (circle with a diagonal bar). I have tried different versions including Flatpak to no avail. Everything worked fine in 22.04
Edit: Dragging a file from Nautilus to XNView is working normally.
Edit: I downgraded to 22.04, everything works now.
Re: Drag and Drop in Ubuntu 23.04 not working
do you use Wayland?
leunam12
Post by leunam12 »
Yes, I think that is what come by default on 23.04. But I also use Wayland on 22.04 and everything works.
